Event Types
All events display the start time of that event in the left-most column andthe name of that event type; most events display the channel on which the eventis being transmitted. The following is a list of event types:
Note events
Poly After Touch events
Controllers events
Programs events
After Touch events (Channel pressure)
Pitch Bend events
System Exclusive events
Bank Select
The Channel field is where the channel is ‘hard-wired’ into the original track. Remember, using a Metro Output assignment overrides the hard encoded channel assignments of the original track data. You can have up to 16 independent channels within a track when assigned to an Original Port. To change the channel, simply click on the Channel field for each event and enter the channel to which you wish to change it. Ifyour MIDI controller sends out on multiple channels, you can record up to 16channels simultaneously to a single Metro track; those channels can later besplit across multiple tracks using the Expand By Channel option under the Edit menu.
Selecting Events in the Event Editor Window
Recording Controller Events
Recording Program Change Events
Recording Tempo Events
Recording System Exclusive Events
Event Types
