Tremolo
A tremolo works almost like an automatic gain control, making the audio louderand softer in a highly rhythmic fashion. You can use a variety of settings tocreate subtle or extreme effects, repeating quickly or slowly as you wish.
Time
Controls the length between the loudest and softest points in the tremolo.Values can range between 0 and 1000 milliseconds.
Volume 1
Sets one of the volume points for the tremolo effect in decibels. You can usevalues from -0 (silent) to approximately +6 dB.
Volume 2
Sets the other volume point for the effect. Be careful about setting eithervolume too high, since it can easily distort. Set the volumes to different valuesfrom each other; the greater the difference in values, the more dramatic thetremolo effect.
Method
Choose between Sine, Square, and Sawtooth waveforms. This setting determineswhether the tremolo effect will sweep smoothly between Volume levels 1 and 2(Sine), whether it will jump sharply between them (Square), or whether it withchange steadily to and from each point (Sawtooth).
Adding Effects in Real-time
Adding Offline Effects
Effects Tutorial
Tremolo
