Delay
The Delay effect will help you add depth to a track (when the time interval is short), or can be used to provide a 'slapback' effect or an echo (when the time intervals are longer).
Delay
Sets the length of delay milliseconds. You can use values from 0 to nearly1000 ms (equivalent to 1 second).
Feedback
Controls the amount of signal the delay will feed back into itself. As youincrease this value, you will notice a more pronounced echo, until the feedbackactually becomes louder than the original sound. Setting this too high can resultin distortion. You can use values from 0 to nearly 100 per cent.
Volume
Sets the volume of the delay effect in decibels. Use values from 0 (fullvolume) to -8 (zero volume).
Adding Effects in Real-time
Adding Offline Effects
Effects Tutorial
Delay
