The Controller Display Typing the k key, or choosing Controller from the Data Type pop-up menu within the current track's titlebar, changes the desired track to show graphical controller data within the Graphic Editor window.The Controller display allows you to graphically 'draw' values for any available MIDI controller. Choosing Controller from the Data Type pop-up menu within a track's titlebar adds an additional Controller Type pop-up menu item to the current track's titlebar display; use the Controller Type pop-up menu for designating which controller name/number is to be displayed.The list of available controllers shown within the Controller Data Type pop-up menu is dynamically linked to the Controller Names specified in the Favorite Controllers dialog under the Setup menu. Audio Tracks use a similar display for their Volume and Pan data.The Favorite Controllers dialog allows you to give custom names to any controller number. Favorite Controllers also designates which controller names you want to see displayed in theController Type pop-up menu.Use the Arrow Tool for range selection, or the Pencil or Curve Tools to draw in or manipulate existing controller data. See Also:Continuous Data Extract Data |
