Deleting Outputs/Faders
To delete Outputs/faders:
  1. In the Instruments Mixer window, click directly on an Output Name at the bottom of the window to select that Output.
  2. Shift-click any additional outputs you want to delete.
  3. Choose Cut or Clear from the Edit menu, or type the Delete key.
Adding Outputs/Faders
The Instruments Mixer Window
Deleting Instruments/Faders
