Setting a program number in the
Pgm
field sends a Program Change to the Output. Use the
Pgm
field for auditioning different patch changes on your MIDI device withoutcommitting them to a track.
Program Change events contained in MIDI tracks override Program settings associated with particular Outputs. Use the
Pgm
field in the Tracks window to encode a physical Program Event at the beginning of that track. Audio Tracks ignore an Outputs Program designation.
Output Name
Faders
Master Fader
Snapshot Button
