Snapshot Button
Clicking on the
Snapshot
button during play or record sends out every Outputs Volume and Pan settings across all Metro ports and channels.
Note:
When clicking the
Snapshot
button during record, only the Outputs assigned to Metros Record port are recorded into the record-enabled track.
Clicking the
Snapshot
button when play or record is not engaged inserts physical Volume and Panningevents (Controllers 7 and 10, respectively) at the current insertion pointacross all selected tracks. Use the Tracks window Overview to select an insertionpoint across multiple or noncontiguous tracks; then click the
Snapshot
button to encode the Controller and Program Change events into the selectedtracks. This feature is very useful for placing Controller and Program Changeevents at any location within single or multiple tracks. Be careful to removepreviously inserted controller events if you need to use the
Snapshot
function more than once at the same location on a track.
Output Name
Faders
Master Fader
