You can click directly in the
Pan
field and set a Pan value, or you can click directly on the
Pan Dial
and move it left or right.
Pan
field changes can be recorded as long as the current Output is assigned to the specified
Record Port
under
MIDI Setup
in the
Setup
menu (or, when running OMS or MSS, the Output is selected via the
Record From
pop-up menu in the
MIDI Setup
dialog).
If you click to the right of the
Pan
field, placing a dot there, the pan value (Controller 10) will be sent each time Metro plays. Pan values encoded as Controller events within tracks override the Pan values associated with particular Outputs.
Note:
Metro allows the Pan knob to be reassigned to any controller, or configured tosend out System Exclusive data.
Output Name
Faders
Master Fader
Snapshot Button
