Setting a value in the
Data
field adjusts the Controller data value for
Controller
number that is set in the
Define Outputs
dialog box. Moving a fader up or down will affect the numeric
Data
field display, as well as adjust the data value of the currently assigned
Controller
number (specified in the
Define Outputs
dialog). Metro Output Sliders default to transmitting Controller 7 (MIDI Volume).
If you click to the right of the
Data
field, placing a dot there, the Data value will be sent each time Metro plays.
Note:
Metro allows the Data knob to be reassigned to any controller, or configured to send out System Exclusive data.
Audio Tracks handle volume in the same way as MIDI Tracks, however, special 15bit automation (32,767 steps) is derived from the Audio Track’s volume (controller 7) information.
Output Name
Faders
Master Fader
Snapshot Button
