Master Fader
The Master fader, located in the right of the Instruments Mixer window, scales all fader settings in relation to each individual setting. Moving the Master fader affects all MIDI and Audio Track fader setting values, but it does not cause the other faders to move. Only faders associated with Instruments assigned to the same port as Metro’s Record port will be recorded.
Output Name
Faders
Snapshot Button
Master Fader
