Use the
Bank
pop-up menu to select from any number of Bank Select messages and/or Program Name lists that have been assigned to an Outputs port. Create and assign Bank Select messages and Program Name lists in the
Program Names
dialog under the
Setup
menu. The Abbreviation entered in the Bank Select message or Program Name list’s
Abbrev
field appears in the corresponding Outputs
Bank
pop-up. The
Bank
pop-up remains empty until a Bank Select message or Program Name list is assigned to the Outputs port.
Option
-click the
Bank
pop-up to view and reassign all banks, even if they're already assigned to a different port. Audio Tracks ignore an Outputs Bank designation.
Output Name
Faders
Master Fader
Snapshot Button
