Save As
Choosing Save As saves the current Metro document file to disk and gives you an opportunity to name or rename the document orsave it to a different drive. If you save a file under a different name, theoriginal version will remain intact.
After using Save As, the current Metro document becomes the Saved As document, which now has thename that you typed into the Save As dialog box.
Save
Save As Portable Bundle
Save As
