Update Outputs Under OMS/MMS
Please be aware that if you make changes to your OMS or MMS Studio Setup document and you want your Outputs or faders to reflect these changes, you should create new Outputs.
To do this, choose Modify Outputs and Busses from Metro’s Special menu; then click on the Make Outputs reflect MIDI setup document button and click OK. Metro will look at the Current OMS or MMS Studio Setup document for the number of output device channels currently defined and make the same number of Metro Outputs for each of them. If you do not see all the channels that you expect then most likely your studio setup document is not correct.
note02.gif Note:
OMS or MSS cannot dynamically update METRO Outputs—this must be done manually within the Modify Outputs and Busses dialog.
exclaim2.gifImportant: OS 9 users only.
If you don’t create a Studio Setup document and make it Current before starting METRO, a series of dialog boxes will appear guiding you through the process. Be sure to read the instructions that came with the OMS Setup (or OMS Setup+Patches) application if you need additional help following these steps.
Update Instruments Under OMS
