Setting the Pitch Bend Range To set the Pitch Bend range, first open the Instruments Mixer window. Then double-click on the desired Output's name at the bottom of the Mixer window.Set the Pitch Bend sensitivity item to the same value as your MIDI device'sPitch Bend range. Pitch Bend sensitivity is measured in semitones, so if you setthe value to 12 (and your MIDI device has a pitch bend range of 12), Pitch Bendevents will have a range of up to one octave. See Also:Pitch Bend |
