Setting Event Start Time in the Section Event Editor Window
You set event start times using the
Bar/Beat/Clock
column in the left portion of the Section Event Editor window. Events can beviewed in the
Bars Display
or
SMPTE Display
which can be selected under the
Switches
menu.
Just click directly on the value you want to change; then move the mouse up ordown to raise or lower the value. Alternately, you can type in the start timevalue.
Initial Tempo, Key Signature, and Time Signature Events
Selecting Events in the Section Event Editor Window
Selecting Multiple Events in the Section Event Editor Window
Inserting Section Events
Placing Events at Precise Locations in the Sections Event Editor Window
