Placing Events at Precise Locations in the Sections Event Editor Window
You can either specify an insert location before inserting the event or placethe start time of the event after you insert it.
To specify an insert location before inserting the event, select the event orrange of events, then press
Command-=
or choose
Set Selection
from the
Edit
menu, set the desired location in the dialog box, and click
OK
Alternately, you can insert the desired event and then adjust its start timeto move the event where you want it. Click on the event’s
Bar/
Beat/Clock column and enter a new value to adjust its start time location.
Time signature events can only occur on Bar boundries.
Initial Tempo, Key Signature, and Time Signature Events
Selecting Events in the Section Event Editor Window
Selecting Multiple Events in the Section Event Editor Window
Setting Event Start Time in the Section Event Editor Window
Inserting Section Events
