Saving Your Recording as a Metro FileBefore continuing, save your recording as a Metro document file. Later inthis tutorial, you’ll record more tracks to form a Section, and then record more Sections to save within your Metro document file. It’s always a good idea to save your work as often as possible; unforeseenproblems can cause file loss or damage. It is a good idea to save your work tofloppy disks at least once a day so that you have a backup of your work.To save your recording as a Metro file:- Choose Save or Save As from the Edit menu.
- Type a name for your Metro file, then click OK to save it to a drive ordiskette.
Metro saves your file under the name you designate. Proceed on to Enlarging the Transport Window. |
