| Song Building ModeSong Building mode lets you listen to, and reject, passes as you record them,recording onto one or multiple tracks depending on whether you’ve chosen Overdub or Replace The number of passes you can record depends onthe number of MIDI record tracks you specify in the Record/Play dialog box(before Loop Recording, you must choose both a Record mode and a Loop Recordingmode). |
