Recording Data on Multiple Faders
You can also simultaneously record multiple faders, each associated with a different Output and a different type of controller data. You can record all the faders or specific groups of faders.
To record all faders simultaneously:
  1. Begin recording.
  2. Press and hold the Shift key.
  3. While holding the Shift key, click on a single fader and move it; all faders will move along with the fader you’re dragging. Keep in mind that only the faders assigned to the same port to which the record track’s Output is assigned will be recorded.
You can also use the Master Slider to record the movement of all faders that are assigned to the same port as the record track’s Output assignment.
Recording Controller Events Using Faders
Faders
Saving Faders and Output Setups
