Interpret Overlapped Notes AsWhen converting Note On/Note Off to duration, as sequencers do, the dataitself may be ambiguous if two notes of the same pitch are overlapping on the same channel. This option allows you to specify how you want Metro to interpret this typeof ambiguity. If you are experiencing unexpected results of MIDI playbackafter importing a MIDI file, try changing this setting and re-importing.Other General Preferences options:Thru Settings Middle C Is Note Colors See Also:Timing PreferencesBuffers Preferences |
