Timer PaneTiming Preferences
The Extended Time Manager
(ETM) is available on later Macintosh computers and is a more
compatiblemethod of deriving internal sync.
The following option is not available in OS X. The VIA Timer
is a timer chip and is available on most Macintosh computers.
Regardless of which timing mode you choose, make sure that Appletalk is
disabled when using Metro. If Metro behaves erratically during
playback, try choosing alternate timing modes and turn Virtual Memory
off. .
Note: Because
of the way Apple’s Sound Manager works, be sure to use ETM if you’re
using audio files and/or internal samples; otherwise, timing accuracy
willbe compromised.
Preferences
Dialog
General
Pane
Buffers
Pane
Movie
Pane
JukeBox
Pane
Buffers
Preferences
