MIDI Recording Tutorial
In this tutorial, you’ll be playing back from the same MIDI device that you’re recording from, so you’ll be using Ports on all tracks. Ports allow a track to play the device and the device channels originally recorded on that track. At start-up, Metro initially assigns Ports to all tracks in the Trackswindow. Ports also allow each track to record up to 16 independent channels and playback separate events on separate channels
There are two types of Outputs you may work withMet90000.gifPorts and Metro Outputs. When either running under OS X (using MIDI System Services) or under OS 9 with OMS is installed, Metro can also automatically extract Metro Outputs from your Current Studio Setup document. For information on how to set up a custom Metro Output configuration, see Using Outputs, Ports, and Faders. For details about Metro Outputs, see Outputs Under OMS or MSS.
In this tutorial you learn the following skills:
Setting a Port to the Record Track
Enabling the Metronome Click
Setting the Record Mode: Replace or Overdub
Beginning Recording
Naming Your Track
Viewing Note Data
Playing Back the Track
Playing From a Selection or Bar Number
Adjusting Note Velocity
Saving Your Recording as a Metro File
Enlarging the Transport Window
Playing and Setting Cues
Looping Playback of Your Track
Adjusting Current Playback Tempo
Auditioning Programs
Looping Playback of an Area Within Your Track
Looping Cues
Recording Another Track
Displaying Multiple Tracks in the Graphic Editor Window
Selecting Tracks in the Graphic Editor Window
Naming the Current Section
On-The-Fly Recording
