Naming the Current SectionTo name the current Section:- Choose Sections from the Windows menu.
The Sections window appears. The name of your Metro document appears in the window's titlebar. The name of the current Section is highlighted.- Double-click the name 'Untitled,' which is highlighted.
- Type a Section name in the name field that appears, and press Return.
You'll see the Section name displayed in the Sections window and in the title bar of that Section's Track window. You can edit the Section name in the same way you entered it. To make a Section the current Section, click its name in the Section window.Before the last step of this tutorial, save all the recent changes you made bypressing Command-S.Now let's finish this tutorial by trying some On-The-Fly Recording. |
