The Lyric List
Name, select, and assign lyrics in this section.
The lyric list contains the following elements:
Lyric Selector Dots. Click on these dots to select a lyric for editing. The dot changes to a smalltriangle.
Name Column. Use this area to name each lyric in the Lyric list. Click in this area andtype to change the name.
Voice column. Use this column to assign the lyric to a specific voice. METRO supports up toeight voices.
Verse column. Use this column to assign the lyric to a specific verse. METRO supports up toeight verses per staff.
Measure column. Use this column to select a starting measure for each lyric. METROautomatically flows lyrics beginning on the first note in this measure.
Lyric Overview. This column provides a display of the first few words from each lyric line, tohelp you identify lyrics. You cannot edit lyrics in this area, only viewthem. Use the Lyric editing area to edit them.
Button bar
Lyric editing area
Using the Lyric Window
The Lyric List
