Looping Options
When you choose Looping from the special menu, the Looping options dialog boxappears. From the Loop dialog box you can set the number of times a selectionwill loop, by entering a number in the "N" times field, or you can select theFor Many hours option which will loop the selection indefinitely. Metro does notloop audio tracks.
To loop an area in a track:
  1. In the Graphic Editor window, select the area you want to loop.
  2. Choose Looping from the Special menu.
The Looping Options dialog box appears. Notice that the beginning and endinglocations of your selection are entered in the From and To fields in the Looping Options dialog box.
  1. If you want the range to loop a specific number of times, click the Loop 'N' Times button and enter the desired value.
  2. If you want the range to loop virtually infinitely, click the For Many Hours button.
  3. If you want, reselect the area you want to loop by filing in values in theFrom and To fields.
  4. Click OK.
Notice that Loop icons now appear within the Graphic Editor window at the specified begin and end locations. In the Graphic Editor window you'll see a number next to the Loop End icon, which is the number of times you specified the range to loop. Once playback of the loop begins, you'll see a number next to the Loop Begin icon that designates the cycle number of the loop currently playing.
If you play looped and unlooped tracks at the same time, when the looped trackfinishes the looped section, it skips over enough of the following measures tocatch up to the unlooped track.
In the Tracks window you'll see one of two Loop icons in the Loop column, indicating the track is loop enabled. A Loop icon with a single arrow designates that the entire track is looped (frombeginning to end); a Loop icon with two arrows designates that a range within that track is looped.
Loop Recording
Looping a Track
Looping Cues
Looping Playback of an Area Within Your Track
Looping Playback of Your Track
Clear Selected Loops
Looping Options
