Delete Duplicates
Use Delete Duplicates if two identical events (notes, controllers, etc.) exist in a region ortrack. First, select the region or track to be affected; then choose the Delete Duplicates command. Within the Delete Duplicates dialog box, specify in clocks thedesired threshold between note attacks in the Note within 'N' clocks field. One of the duplicate events falling within the specified thresholdwill be deleted and the other will remain.
You can also delete duplicates in all tracks of a Section by selecting aSection in the Section window, then choosing the Delete Duplicates command.
Editing
Delete Duplicates
