SysEx in Graphic EditorSystem Exclusive events that you record will be displayed in the GraphicEditor if you check the Show SysEx in Graphic Editor option under the Switches menu. SysEx events appear as vertical bars in the Graphic Editor window. Youcan also name SysEx events by double-clicking the vertical bar, then namingthe event in the System Exclusive Event Edit dialog box that opens; the name of the SysEx event will appear within thevertical bar. See Also:Insert SysEx Data SysEx |
