Selecting Record CriteriaYou must select the MIDI data types you want to record. If a data type is not checked, it will not berecorded. Once you select your Record Criteria, be sure to save your settingswithin any of the Preferences dialogs (File menu).To select Record Criteria:- Choose Record Criteria from the Setup menu.
The Record Criteria dialog box appears. - Check the data types you want to record.
 - Click OK.
See Also:Record Criteria |
