Name and Place Chord ChangeType in the root key in the Chord Change field and choose the desired chord type from the Chord Change pop-up menu. Click on the small triangle to the left of the Chord Change field if you want to transfer the Chord Change name to the Name field at the top of the Markers dialog box. If you want to place the Chord Change at a location other thanwhere you clicked, enter the desired location in either Bar, Beat, Clock time orin SMPTE time. Note: You can create new Chord types within the Scales/Chords dialog under the Setup menu. See Also:Markers/Chord Changes Lock Markers or Chord Changes Delete Markers and Chord Changes |
