Recording a MIDI Bass line
OK, as the next step, let’s add a 4 bar MIDI bass line over top of the drum loop and high hat tracks:
- Within the Transport window, click and drag the MIDI Thru Channel popup to setit to channel 1.
- Click the Play button in the Transport window or press the spacebar to startplayback. As the sequence plays, select a bass sound on your General MIDI soundmodule and work out a 4 bar bass line to go along with the drums.
- Click the Stop button in the Transport or press the spacebar once you’re figured out your part.
- From within the Tracks window, click the R column to record enable track 4 forrecording.
- Click and drag the Output popup on track 4 to assign it to Channel 1 of your General MIDI sound module.
- Click the Record button in the Transport or press Option-R to begin recordingyour MIDI bass line to track 4. (Remember, the count off is set to 1 bar.)
- Click the Stop button in the Transport or press the spacebar after you’ve played in at least 4 bars worth of material.
- Within the Tracks window, click the Loop button to loop the bass track andspecify 4 bars for the track duration.
- Choose Save from the File menu. This saves the contents of the active sessionto the current Metro file.
The next step in your first session is Recording Another Track.
