| Playback TransposeThis column in the Tracks window (see Note, below) allows you to enter a valuein semitones for the playback transposition of a track. This non-destructivelyalters the pitch of MIDI notes in the track on the fly during playback. Itdoes not alter the data on the track, merely affects how it is output duringplayback.To select a transposition value, click in this column and drag vertically orenter a value from -48 to +48.Note: You can toggle on/off the display of the Bank, Pgm, Quantize, Transpose andVelocity fields in the Tracks window by using the display options pop-up menu.This pop-up menu is located above the track number column in the Tracks window. |
