Velocity
Choose the Selection Filter’s Assign To submenu command. If you want notes with durations within a particular rangeto be selected for edit operations, check the Durations box and set the desired range. If you want notes with velocities within acertain range to be selected, check the Velocity box and set a range.
Adjusting Note Velocity
Velocity Stem Edit Tool
Rest, Note Value, Velocity, % of Value
Velocity
