| PrintUse this command in the File menu to print all or part of your score. METRO displays the Print dialog boxfor the printer you have currently selected (via the Chooser command in theApple menu). See your printer manual for specific information about the variousprint options.If your printer requires AppleTalk and you want to record and playback MIDIwithin METRO, be aware that AppleTalk can interfere with MIDI communication overboth serial ports (modem and printer). Generally, MIDI recording suffers ifAppleTalk is on. For this reason, you may want to turn it off until you areready to print your score. |
