Import MIDI FileAlmost all MIDI programs allow you to create Standard MIDI files. You can import any Standard MIDI Files (SMF) into Metro. Standard MIDI Filesmust be Type 0 (single-track merged), Type 1 (multitrack) or Type 2 StandardMIDI Files (SMF) in order to import them. Type 0 and Type 1 files are verycommon and can be found in abundance on the Internet and elsewhere. You can importup to 32 MIDI files (one for each section) into a document. You can also importMIDI files using the File > Open menu command, but this method overwrites theentire document. Drag-and-Drop Support for MIDI FilesYou can import one or more MIDI files by dragging and dropping MIDI files onthe Metro application icon. Each MIDI file opens as an independent Section inthe current Metro document. See Also:Importing MIDI Files Exporting MIDI Files Saving in Standard MIDI Format |
