Bank The Bank setting allows Bank Select messages to be sent to any Metro Output. A Bank Select message must first be created for a specific Output (via the Program Names option under the Setup menu) before it can be sent. Once a Bank Select message has been created for a particular Output, it will appear in the Bank pop-up menu only after the Output and channel for which the Bank Select message was originally created are assigned to the active track in the Graphic Editor window. See Also:Bank Select Selecting a Bank Select Message in the Instrument Mixer Window Sending Bank Select Messages |
