Audio Display - Audio RegionsAudio waveforms represented in the Graphic Editor window are shown as Audioregions. An audio region is a reference to a parent audio file located on one ofyour local drives. Regions act as pointers to an audio file allowing agraphical playlist to be created within the Notes display. You can display several different parameters of an audio file in the GraphicEditor window. To display audio parameters:- In the Graphic Editor window, display an audio track by clicking the trackname in the track titlebar and choosing a track from the popup menu.
In the track name titlebar, the type of audio data that the Graphic Editorwindow currently displays is listed next to the track length field.- To display different audio data, click the name of the type of data to open upthe display data type popup menu.
- Choose one of the following options:
- Audio
displays the audio waveform - Volume
displays audio volume - Pan
displays the pan for this track - Tempo
displays current tempo graphically - Send Vol:
displays the send volume of an auxiliary bus - Send Pan:
displays the send pan level of an auxiliary bus
Selecting Import Audio File from the File menu imports an entire audio file within the first open track and displays itas a single audio region starting at the beginning of the track (1:1:000).Metro calculates an overview for the imported audio region so that it can begraphically edited and manipulated nondestructively (the original audio file willnever be altered). For example, Copying a 1 Bar selection of an audio region overand over across a track will not create additional copies of the audio file onyour hard drive, Metro instead points back to the original audio file using itas a reference for the playback of the copied regions. Such is the beauty of arandom access nonlinear digital audio environment, as found here in Metro. You can also record external audio directly into an Audio track. Selecting the 'R' button in the track's titlebar record-enables the track. The Record Device specified within the Digital Audio dialog (Setup menu) determines your record source. Use the track's Levels display in the Tracks window to view the input levels from your record source. When recording into an analog input, such as the Macintosh sound input, you'll need to adjust the input levels on your mixing board or directly from the record source. Note: Metro also allows recording from a digital input if using an audio card that supports it. Input levels cannot be adjusted within Metro when recording from a digital source. Use an external mixer. See Also:Audio Region Editing Working with Audio Tracks and Audio Regions |
