Drum Set Editor
The Drum Set Editor dialog allows you to create, edit, and manage Metro Drum Set files. The Drum Set Editor dialog displays the Drum Name assignments for any Drum Set currentlyaccessible within the Metro application. Drums Set files can also be exported andimported directly to and from a disk within this dialog.
Drum Set files consist of lists of Standard Drum Names and User Drum Namesthat are assigned to specific MIDI note numbers. Any changes made to a Drum Setwithin the Drums display of the Graphic Editor will be saved to the originalDrum Set.
Standard Drum Names are hard wired into the Metro program and cannot berenamed or deleted; User Drum Names can be created on the fly and named at will. Both Standard Drums Names and User Drum Names can be assigned to any MIDI notenumber within a Drum Set. However, be aware that User Drum Names will not beaffected when transposing a Drum track from one Drum Set to another; only StandardDrum Names will be transposed.
You can transpose a Drum track from one Drum Set to another by Option-clicking the Drum Set pop-up (within the Drums display of the Graphic Editor) and choosing anotherDrum Set.
Select Drum Set
Save Set As
Import Set
Export Set
Delete Selected Set
Add User Drum
Drum Assignment Display
Creating and Naming a New Drum Set
Showing All Drum Names within a Drum Set
Transposing from Drum Set to Drum Set
Working with Drum Sets
Drum Set Editor
