| Select Drum SetUse the Select Set pop-up menu to display the contents of a Drum Set within the Drum Set dialog box. The currently selected Drum Set will be affected by all editingoperations within this dialog. The Select Set pop-up menu displays Drum Sets that have been previously saved to the Metroapplication or modified through Drum Set editing operations performed within theDrums display of the Graphic Editor (e.g., choosing Add New Drum from the Drum Names pop-up). Choose New Set from the Select Set pop-up menu in order to create a new Drum Set from scratch; or click the Import Set button to import an existing Drum Set file from disk. Click the Save and Done button to save changes and exit the Drum Sets dialog box. |
