Digital Audio Dialog: Device Options
Click the Device Options button to open a Parameters dialog. The dialog appears differently depending on which sound card you have selected in the Digital Audio dialog box. For Core Audio see below. The following lists each dialog and its parameters:
  • Sound Manager Parameters
  • Play Through
    Input Gain
  • ASIO Setup
  • Audio Buffer Packet Size
    Clock Source
    Record Left (Mono)
    Record Right
  • Stud I/O Parameters
  • Clock Source
    Record Left (Mono)
    Record Right
    When monitoring send other tracks
  • Korg 1212 I/O Parameters
  • Clock Source
    Record Left (Mono)
    Record Right
    Left Analog Input Gain
    Right Analog Input Gain
    note02.gif Note: Use care when working with Playthrough so that you don’t accidentally create an audio feedback loop.
    Core Audio
    The Korg 1212 I/O
    The Sonorus STUDI/O
