| Clock SourceFrom this menu select the device you want to use as the master. All otherdevices (DAT for example) are slaves to this device. The two basic types of clocksource are internal and external. Depending on your sound card and which devicesyou have connected to your system you will have different options for clocksource.Both internal and external options are followed by a sampling rate.If you are recording analog audio into your computer, select Internal. |
