| The Korg 1212 I/ONote: this information may also appear in your Metro User’s Guide, but is included here for your convenience.If you own a Korg 1212I/O audio card, you can use the audio card to record andplay audio in Metro. Use the Digital Audio Setup dialog, reached through theSetup menu’s Digital Audio command, to configure Metro’s audio settings.In the Digital Audio Setup dialog, click Recording Settings to configure theKorg 1212 I/O card. You’ll see the following dialog box appear:Monitor OnClick this checkbox to use play any incoming audio signal through the Korg1212 I/O’s outputs.Input GainsWe recommend you leave the input gain at 100% to get the clearest recordings.If your audio distorts when you record, reduce the volume of the incomingsignal with an external mixer.Clock SourceThis setting determines whether Metro will synchronize its audio to the audiocard or some other source.Record LeftUse this setting to choose which incoming audio source on the 1212 I/O will beused for mono recording, or as the left channel in a stereo track. You canpick from any of the card’s combination of 12 analog, SPDIF or ADAT optical I/O inputs.Record RightUse this setting to choose which incoming audio source on the 1212 I/O will beused for the right channel in a stereo track. |
