Stereo FlangeSimilar in function to the Stereo Delay and Stereo Chorus, the flange effectcan provide a spacey or ethereal sound texture to your audio.Dry MixControls the volume of the original, unprocessed signal. This controlattenuates the signal, using values from 0 (full volume) to -8 (zero volume).Wet MixControls the volume of the processed signal. This control attenuates thesignal, using values from 0 (full volume) to -8 (zero volume). L Delay Sets the delay interval in the processed effect's left channel. The flange effect allows between 0 and 20 milliseconds of delay; use a smaller value for a 'tighter' sound and a larger value for a 'looser' sound. R Delay This functions identically to the L Delay setting, except it controls the processed effect's right channel. R FBackControls how much of the processed signal is fed back through the effect inthe right channel. Values range from 0 to 100 per cent. A higher feedback settingwill thicken the flanging. L FBack This functions identically to the R FBack setting, except it controls the processed effect's left channel. X FBackControls how much of the processed signal is fed back through the effectbetween the left and right channels. A higher value will thicken the flanging andprovide interesting results, especially when the L Delay & RDelay and L FBack & R FBack settings are set to very different values.ModDepthControls the amount of detuning. Setting this very high will result in asweeping texture. A lower setting will create more subtle flanging.Mod RateControls the rate of detuning. Low values create a slow sweeping effect, andhigh values create a dramatic texture almost like a timbre. LFO Type (S, L, T) Determines whether Metro will use a Sine wave, a Logarithmic wave, or a Triangular wave as the basis for detuning the flanged signal. Because the delay times are so short, you will probably hear these different settings as changes in timbre or texture. A sine wave creates a smooth up and down effect. Logarithmic waves create a smoothly rising effect that drops sharply at the end before repeating. Triangular waves create a smoothly rising effect that begins dropping abruptly after it reaches the 'top' or 'bottom' of the wave. See Also:Adding Effects in Real-time Adding Offline Effects Effects Tutorial |
