Effects Window (Instantiated
Effects/Synths)
Modern rack editor:
For specific info, click on the appropriate part of the
image (of the retro editor) below:
The Effects window houses Metro's active real-time effects,
including VST-compatible Plug-ins and AudioUnits. Use the
Effects window to view and modify the parameters of real-time
effects and to control the routing of multiple Plug-ins.
Information on routing track multi-outs can be found here.
Hint: A plug-ins editor window can be reset to its default size
by holding the shift-key while pressing the edit button.
Right-click on the track bar to bring up the effects
input/output menu:
Selecting an item from the inputs or outputs menu will take
you to the corresponding window for that item. Sidechain stereo
inputs can be selected here for all pairs of stereo inputs to
the effect chain. The sidechain audio input will then be fed
from the corresponding track.
Right-click on the individual rack item to bring up the
individual plug-in contextual menu:
Clear removes the
plug-in.
Clear All Automation
removes all of this plug-in's automation from the selected
track or aux buss.
Record MIDI, if
supported by the plug-in, will enable the plug-in for MIDI
input. When enabled, a new input will appear in the graphic
editor and track window input select popups. Great care should
be taken not to create a MIDI feedback loop. This can happen if
you record MIDI and then route the MIDI data, via MIDI-thru,
back to the plug-in.
Show In Plug-ins
will reveal the instantiated plug-in in the plug-ins window.
Rack Color can be
specified here and will be associated with the category of
plug-in, as specified in the plug-ins window. This allows, for
example, all reverbs to be red in the rack.
Set up plugin on a track or an aux buss
To set up an effect, drag a plug-in from the plug-ins window
to the effects window or click the downward pointing grey
triangle (as shown in the Modern rack editor picture above) to
bring up the plug-in menu. The track bar row, at the top of the
effects window, is where you select what to view; a track or
aux buss. After a VST or AudioUnit plug-in is dragged to this
window, it is installed as a real time effect on the selected
track or aux buss.
Track or Aux Buss Name
Popup
Click on the name of the track or aux buss to bring up a
popup menu to change to a different track or aux buss.
View
The generic view contains pan knobs as illustrated above.
Click on the pan knob and rotate as you would a real pan knob.
If an effect has an editor, there will be an edit button
instead of pan knob parameters. Option-drag the plug-in to the
effects window to override the editor and display the plug-in
in its generic view. Editor views are opened in their own
window and that window is added to the window menu.
Note: AudioUnits numeric fields may be edited
by clicking and typing a number.
Presets
Pop up windows for each effect allow saving and restoring of
presets. Metro automatically scans its folders for preset files
that it is aware of. Including its native format, .fxb files
and others. Metro (6.0.7 or greater) can be configured so that
program changes sent to a plug-in will change the preset (see
MIDI Event Filtering).
MIDI Event
Filtering
The presence of the MIDI icon indicates that this plug-in
accepts MIDI data. Clicking on this icon will bring up the MIDI options dialog
for effects where you may specify which events reach the
plug-in and which events are filtered.
Setting up an Aux Buss
To set up an aux buss, select Modify Outputs and
Busses from the special menu, select 1
for number of busses desired, select the output port and press
ok.
If you want multiple outputs from an effect you need to
create more than one aux buss. You may then assign the outputs
to different aux busses (using the aux bus routing popups
described below) and even add more effects.
Set up an AudioUnit Music Effect
If a MusicEffect is used, the only logical place to use it
(because it needs both MIDI and Audio) is on an aux buss. To
use a music effect follow these steps.
- Set up the aux buss as outlined above.
- In the effects window, select the aux buss and
drag the plug-in from the plug-ins window.
- Go to the Instruments Mixer
window and make sure it says Main in the popup on the
top right of the window.
- On the output assigned to an audio track (that
you want sent to the Music Effect) pull the volume fader
all the way down.
- Select Aux 1 from the popup on the right.
- Select pre-fader for the output used in step IV
and set its fader all the way up.
- To send MIDI to the aux buss, create a new track
and assign its output to the port corresponding to the
effect that was dragged in step II. This can be performed
either from the graphic editor
or the tracks window.
Selecting Effect and
Rearranging the Order of Effects
If you click on the name of an effect it will become
selected. Use clear to clear the effect. Control-click (or
right-click) on effect or effect rack to bring up a contentual
menu with options to clear automation data and more.
The Effects window shows all the real-time Plug-ins assigned
to the current track. You can add as many effects to a track as
your processor permits, allowing you to add a tremolo effect
before a delay, for example. If you have more than one Plug-in
assigned to a track, you can rearrange their order by dragging
their Name field either up or down. Plug-in effects parameters
are directly accessible within the Effect window.
Metro’s real-time effects employ in-line signal
routing. Effects are inserted into an audio channel in a series
configuration with Send and Return controls for the
corresponding Audio channel. Each Audio channel requires its
own effect configuration.
Determining the
Number of audio Inputs and Output to an Effect
The number of dots to the left of an effect determines the
number of mono audio inputs the effect is expecting.
The number of dots to the right of the effect name
determines the number of mono audio outputs an effect is
outputting. As of version 6.3.6, clicking here will bring up a
popup menu(AudioUnit plug-ins only) allowing the user to
configure the number of outputs.
Thus for the effect chain, the number of inputs will be the
number of inputs the first effect in the chain is expecting and
the number of outputs will be the number of outputs that the
last effect in the chain is providing. If the effect chain is
installed on an aux buss the data may be routed with the aux buss routing popups.
Prior to 6.3.6, If the number of outputs of the effect chain
is greater than two and the effect chain is installed on a
track, all outputs except the first two will be lost.
Track Multi-Outs
As of 6.3.6 and greater, any plug-in that has more than one
output can be configured as a multi-out. Multi-outs are
configured by selecting 'configure as multi-out' from any of
the track routing popup menus. The track routing popups are
located in the same location as the aux buss routing popups, when a
track is selected, which is directly to the right of the track/aux buss name popup. Once
a track is configured for multi-outs, each effect output can be
configured as mono or stereo and assigned to individual mixer faders. To change the
mono/stereo configuration of an effect's output, click on the
output numbers directly to the right of the thick up-pointing
arrow. This will toggle the selected output(s) between mono and
stereo. In the picture below, note that the iDrum
plug-in is configured as stereo out from effect outputs 1 and 2
to Metro output 'Built-in Aud-1' and then mono out from effect
output 3 to 'Built-in Aud-2', and then stereo out from effect
outputs 4 and 5 to Metro output 'Built-in Aud-3', etc. Even
simple stereo output plug-ins can be configured as two mono
outs.
The total number of effects outputs can be configured by
clicking on the number of dots to the right of the plug-in name
for Audio Unit plug-ins only. If a plug-in has more than 8
outputs, as in the picture below, it will show a numeric value,
in this case '16 outs'.
The multi outputs can have their volume and pan automated by
setting up a new track, assigning the same output and inserting
continuous audio volume or pan data. There is currently a
limitation, in that, the first output of a multi-out can only
have an automation track if it contains no automation
(including effect automation) itself.
Aux Buss Routing
Aux busses may have there output routed either out to the
output device or through other aux busses. Each stereo out
corresponds to two outputs from the effect chain. Using the
above image as an example:
There are 2 stereo outs (4 mono outs) from the
DLS/SoundFont2 synthesizer.
These outputs are being routed to aux busses named 'Aux 3'
and 'Aux 4' respectively.
Aux 3 is the currently selected aux buss as it appears in
the left of the titlebar.
The first two outputs will be routed through the other
effects in this effect chain. Namely, the Apple lowpass filter
and then WaveArts
Trackplug before finally being sent to the Aux-3 fader in
the instruments mixer window. The last two outputs will be sent
to Aux 4. Any effects installed on Aux 4 will be applied before
finally being sent to the Aux-4 fader in the instruments mixer
window.
To change the outputs, click on the route names and select a
value from the popup menu.
Select a SoundFont
Bank
When using a synthesizer that supports banks, such as
Apple's DLS/SoundFont2 synthesizer, clicking on the soundbank
name will present a dialog allowing you to select the file to
use as the instruments sound bank. Any program name lists will
automatically be loaded for the corresponding synthesizers
port.
Effects terms:
The Send slider
determines how much audio signal gets sent to the first effect
in the chain.
The Dry signal is
mixed with the output of the last effect in the chain and then
sent to selected stereo outputs.
The Wet slider determines
how much of the last effect in the chain gets mixed with the
dry signal before being sent to the stereo outputs.
The Lock Icon, when
present, links the movement of the wet slider and dry slider to
act as if they were a single control.
The Bypass button, when
on, bypasses an effect in the chain.
The Power button, when
off, bypasses all effects in the chain.
Dry
Send
Return
Bypass
Name
Preset Menu
Effect
Parameters
Note: Real-time effects are
very CPU-intensive. Even on the fastest of machines, Metro will
be able to handle a limited number of simultaneous effects. For
this reason all real-time effects also have the capability to
process an Audio Track or selection off-line (non real-time).
Access any of the Real-time effects within the Audio
submenu for off-line nondestructive processing.
Adding Effects in
Real-time
Adding Offline
Effects
Effects
Tutorial
