NameDisplays the name of the corresponding Plug-in. Click and drag from the namein order to change the routing of the signal path or select and clear toun-patch an effect in the current track.Metro uses the name also to tell you whether the effect you added is stereo or mono effect by displaying dots in front and behind the effects name. Effects that accept mono inputs display one dot in front of the effect name (). If an effect accepts stereo input, it displays two dots (). For example, an effect that accepts a mono signal but generates stereo output will display one dot in front of the name and two dots after the name, like this: Stereo Delay. |
