| SendThe Send slider effects how much of the dry (unprocessed) track gets sent to the firstPlug-in. The output from the first Plug-in is then routed to the secondPlug-in, and so forth and so on. Before the signal is output the Dry signal is added back into the output of the last Plug-in. Pan and overallvolume information can be controlled from the Instruments window. Think of thissetting as the input amount for the current effects. |
