The Master FaderThe Master fader, located in the right of the Instruments Mixer window, scales all fader settings in relation to each individual setting.Moving the Master fader affects all fader setting values, but it does not cause the other faders to move. Only faders associated with Outputs assigned to the same port as the tracks record port will be recorded. See Also:Faders Grouping Faders |
