Downloading OMSOMS eases the process of getting your MIDI system up and running, and it keeps things running smoothly between all ofyour MIDI software applications once you’re properly configured. The majority of multi-timbral MIDI devices respond to16 channels of simultaneous MIDI information, working with three or four MIDImodules can quickly add up to 64 channels of independent MIDI information.Keeping track of all this data across multiple channels of multiple devices can be quite a task, OMS helps to minimize the burden byassociating names with your devices, rather than numbers. Metro ships with a current version of OMS. New versions of OMS are available at no charge by visiting Opcodes website at: http://www.opcode.com See Also:MIDI Setup MIDI Setup Without OMS Downloading OMS |
