The Program Change Display
Typing the g key, or choosing Program Change from the Data Type pop-up menu within the current track’s titlebar changes the current track to show Program Change messages. ProgramChange messages are represented by a small circle followed by a horizontalline; the horizontal line will extend until the next Program Change message, oruntil the end of the piece if no other Program Change events are present.
Enter new Program Changes using the Pencil Tool, or use the Arrow Tool to modify existing Program Changes by clicking on the small circle. Whenclicking on the circle, a Program Event Edit dialog pops up allowing you to modify all parameters of the existing data(much like the Event Edit dialog within the Notes display).
note02.gif Hint: Be sure to use the Current Cursor Position display (in the upper left corner)as a reference when inserting new Program Change data using the Pencil Tool.
Notes Display - MIDI Piano Roll
Drums Display
The Controller Display
The After Touch Display
The Tempo Display
The Pitch Bend Display
Average Velocity
