Clock SyncSyncing to MIDI Clock is common when dumping MIDI data from drum machines oroutboard sequencers into Metro.To sync Metro to incoming MIDI clocks: - Choose Clock Sync from the Sync setting pop-up menu in the Transport window.
- Choose MIDI Setup from the Setup menu and select the Receive Sync button for the port connected to the master timing device.
Note: OMS/MSS users should verify METROs Receive Sync From setting selected under MIDI Setup (Setup menu). MIDI Clock capable MIDI devices must be specified within the Current Studio Setup document. - Click Record (or Play) in Metro’s Transport; Metro will remain in a pause mode until it receives MIDI Clockdata from the master syncing device, at which time it will begin recording (orplaying).
