Time and Key SignaturesYou can change both time and key signature of any area of a Section you select. If no region is selected when you choose Time and Key Signatures, the entire Section will be selected.You can also open the Time and Key Signatures dialog box by clicking the dooron the Time Signature setting in the Transport window.To edit time and/or key signatures:- In the Graphic Editor or Tracks Overview, select the region you want to edit.
- From the Options menu, choose Time/key Signatures.
The Time & Key Signatures dialog box appears.- In the From Bar 'N' to Bar 'N' fields, enter the range, from start measure to end measure, that you would like changed.
- Choose one or both of the following:
- If you want the Time Signature to change, check the Set Time Signature to boxand enter the desired time signature.
- If you want the the key signature to change, check the Set Key Signature tobox and enter the desired key signature.
- Click OK.
See Also:Initial Tempo, Key Signature, and Time Signature Events Copying SubSection Tempo, Key Signature, and Time Signature Events |
